The toolbar buttons provide quick access to commonly used operational commands. The system displays the buttons that vary depending on the tab you select. However, the Apply, Refresh, and Help buttons are on almost every screen. Other common buttons are Insert and Delete. The following list details the common toolbar buttons.
Apply—Use this to apply all edits that you make.
Refresh—Use this to refresh all data on the screen.
Help—Use this to display online help that is context sensitive to the current tab.
Insert—Use this to display a secondary dialog box related to the selected tab. After you edit the configurable parameters, select Insert in the dialog box. This causes a new entry to display in the dialog box of the selected tab.
Delete—Use this to delete a selected entry.
The following figure shows a sample toolbar.
