Configure a RADIUS Security (RADSec) profile to specify certificate information used by RADSec to develop trust between peers. You can also specify a password used for RADSec encryption.
All the files (certificates and keys) must be in .pem format and copy it to flash /intflash directory.
A new profile directory is created for each new profile in the flash/intflash/.radsec/profile/radsec directory.
Profile configuration file “profile_info.cfg” is available in /intflash/.radsec/profile directory.
You can configure a maximum of 10 RADsec profiles.
- Select RADIUS.
- Select the Secure Certificate Profile
- Select Insert.
- For Name, enter the name for the profile.
- For RootCert, enter the full path for the profile root certificate.
- For Cert, enter the full path for the profile certificate.
- For Key, enter the full path for the profile private key.
- For Password, enter the full path to decrypt the profile private key.
- For RootCertDestFile, enter the file name to use when installing the root certificate.
- For CertDestFile, enter the file name to use when installing the certificate.
- For KeyDestFile, enter the file name to use when installing the key.
- Select Insert.
Secure Certificate Profile Field Descriptions
Use the data in the following table to use the Secure Certificate Profile tab.
| Name | Description |
| Name |
Specifies the profile name. |
| RootCert |
Specifies the full path of the profile root certificate. |
| Cert |
Specifies the full path of the profile certificate. |
| Key |
Specifies the full path of the profile private key. |
| Password |
Specifies the password used to decrypt the profile private key. |
| RootCertDestFile |
Specifies the file name to use when installing the root certificate. |
| CertDestFile |
Specifies the file name to use when installing the certificate. |
| KeyDestFile |
Specifies the file name to use when installing the key. |
