Traffic classification includes functions that examine a packet to determine further actions according to defined rules. Classification involves identifying flows so that the router can modify the packet contents or Per-Hop Behavior (PHB), apply conditioning treatments to the packet, and determine how to forward the packet to the egress interface. Packet classification depends on the service type of the packet and the point in the traffic management process where the classification occurs.
The device classifies traffic as it enters the DiffServ network, and assigns appropriate PHB based on the classification. To differentiate between classes of service, the device marks the DiffServ (DS) parameter in the IP packet header, as defined in RFC2474 and RFC2475. The DSCP marking defines the forwarding treatment of the packet at each network hop. This marking (or classification) occurs at the edge of the DiffServ domain, and is based on the policy (or filter) associated with the particular microflow or aggregate flow.
You can configure the mapping of DSCP-to-forwarding behaviors and DSCP re-markings. Re-marking the DSCP resets the treatment of packets based on new network specifications or desired levels of service.
Layer 3 marking uses the DSCP parameter. Layer 2 (Ethernet) marking involves the 802.1p-bits parameter.
For Layer 2 packets, priority bits (or 802.1p bits) define the traffic priority of the Ethernet packet. You can configure an interface to map DSCP or 802.1p bits to internal QoS levels on ingress. You can configure an interface to map internal QoS levels to DSCP or 802.1p bits at egress. 802.1p bit mapping provides the Ethernet VLAN QoS requirements.
Within the network, a packet PHB associated with the DSCP determines how a device forwards the packet to the next hop—if at all. Consequently, nodes can allocate buffer and bandwidth resources to each competing traffic stream. The initial DSCP value is based on network policies for the type of service required. The objective of DSCP-to-Service Class mapping is to translate the QoS characteristics defined by the packet DSCP marker to a Service Class. The DSCP-to-Service Class mapping occurs at ingress. For each received packet, the mapping function assigns a Service Class.
The switch maintains four mapping tables. These tables translate the ingress 802.1p-bits or DSCP markings to an internal QoS level, and then retranslate the internal QoS level to an egress DSCP or 802.1p-bits marking as follows:
  • ingress 802.1p-bits to QoS level
  • ingress DSCP to QoS level
  • QoS level to egress 802.1p-bits
  • QoS level to egress DSCP
Service Classes
Service classes define a standard architecture to provide end-to-end QoS on a broad range of Ethernet switching and voice products. They function as default QoS policies built into the product. They incorporate the various QoS technologies to provide a complete end-to-end QoS behavioral treatment. The switch includes a built-in QoS implementation for service classes.
The switch includes eight preconfigured queues (corresponding to the eight service classes) on each port of an interface module.
A service class domain classifies traffic as one of the following:
  • Network control traffic (Critical/Network)
  • Subscriber traffic (Premium, Metal, or Standard)
Queue 7 — Critical/Network Service Class (PHB of CS6/CS7)
The switch uses the Critical/Network Service Class for traffic within a single administrative network domain. If such traffic does not get through, the network cannot function.
Queue 6 — Premium Service Class (PHB of CS5/EF)
The switch uses the Premium Service Class for IP telephony services, and provides the low latency and low jitter required to support such services. IP telephony services include Voice over IP (VoIP), voice signaling, Fax over IP (FoIP), and voice-band data services over IP (for example, analog modem). The switch can also use the Premium Service Class for Circuit Emulation Services over IP (CESoIP).
Metal Service Classes
The Platinum, Gold, Silver, and Bronze Service Classes are collectively referred to as the metal classes. The metal Service Classes provide a minimum bandwidth guarantee and are for variable bit rate or bursty types of traffic. Applications that use the metal Service Class support mechanisms that dynamically adjust their transmit rate and burst size based on congestion (packet loss) detected in the network. The following list describes the individual metal classes:
  • Queue 5 — Platinum Service Class (PHB of CS4/AF41)
    The switch uses the Platinum Service Class for applications that require low latency, for example, real-time services such as video conferencing and interactive gaming. Platinum Service Class traffic provides the low latency required for interhuman (interactive) communications. The Platinum Service Class provides a minimum bandwidth assurance for Assured Forwarding (AF) 41 and Class Selector (CS) 4-marked flows.
  • Queue 4 — Gold Service Class (PHB of CS3/AF31)
    The switch uses the Gold Service Class for applications that require near-real-time service and are not as delay-sensitive as applications that use the Platinum service. Such applications include streaming audio and video, video on demand, and surveillance video.
    The Gold Service Class assumes that traffic buffers at the source and destination and, therefore, the traffic is less sensitive to delay and jitter. By default, the Gold Service Class provides a minimum bandwidth assurance for AF31, AF32, AF33 and CS3-marked flows.
  • Queue 3— Silver Service Class (PHB of CS2/AF21)
    The switch uses the Silver Service Class for responsive (typically client- and server-based) applications. Such applications include Systems Network Architecture (SNA) terminals (for example, a PC or Automatic Teller Machine) to mainframe (host) transactions that use Data Link Switching (SNA over IP), Telnet sessions, web-based ordering and credit card processing, financial wire transfers, and Enterprise Resource Planning applications.
    Silver Service Class applications require a fast response and have asymmetrical bandwidth needs. The client sends a short message to the server and the server responds with a much larger data flow back to the client. For example, after a user selects a hyperlink (that sends a few dozen bytes) on a webpage, a new webpage opens (that downloads kilobytes of data). The Silver Service Class provides a minimum bandwidth assurance for AF21 and CS2-marked flows.
    The Silver Service Class favors short-lived, low-bandwidth TCP-based flows.
  • Queue 2 — Bronze Service Class (PHB of CS1/AF11)
    The switch uses the Bronze Service Class for longer-lived TCP-based flows, such as file transfers, e-mail, or noncritical Operation, Administration, and Maintenance (OAM) traffic. The Bronze Service Class provides a minimum bandwidth assurance for AF11 and CS1-marked flows. As a best practice, use the Bronze Service Class for noncritical OAM traffic with the CS1 DSCP marking.
Queue 1 and 0 — Standard (PHB of CS0/DF) and Custom Service Classes
The switch uses the Standard and Custom Service Classes for best-effort services. Delays, loss, or jitter guarantees for these service classes are not specified. However, the Standard Service Class has more forwarding resources than the custom service classes.
The internal QoS level or effective QoS level is a key element in the switch QoS architecture. The internal QoS level specifies the kind of treatment a packet receives. The switch classifies every packet that enters and assigns it an internal QoS level.
Internal QoS levels map to the queues on a port. For example, for an access port the internal QoS level is derived from the port QoS level. For Layer 3 trusted (core) ports, the system honors incoming DSCP or type of service (TOS) bits. The system assigns the internal QoS level using the ingress DSCP to QoS level map.
Important
Important
Remarking packets with an ACL filter does not change the internal QoS level of the packets. You must add the permit internal-qos [value] statement to the ACL filter. For more information, see Internal QoS Level and Remarking.
The system uses ingress maps to translate incoming packet QoS markings to the internal QoS level. The system uses the internal QoS level to classify packets.
Ingress mappings include
  • 802.1p to (internal) QoS level
  • DSCP to (internal) QoS level
The following logical table shows how the system performs ingress mappings for data packets and for control packets not destined for the Control Processor (CP).
Table 1. Data packet ingress mapping
DSCP
Layer 2 trusted
Layer 3 trusted (DiffServ enabled and Access-diffserv disabled)
IP packet
Routed packet
Ingress tagged
Internal QoS
x
No
x
No
x
x
Use port QoS
x
Yes
x
No
x
No
Use port QoS
x
Yes
x
No
x
Yes
Use ingress p-bits mapping
0x1B
x
x
Yes
x
x
4
0x23
x
x
Yes
x
x
5
0x29
x
x
Yes
x
x
5
0x2F
x
x
Yes
x
x
6
x
No
No
x
x
x
Use port QoS
x
No
Yes
Yes
x
x
Use ingress DSCP mapping
x
Yes
No
Yes
x
No
Use port QoS
x
Yes
No
Yes
x
Yes
x
Yes
Yes
Yes
No
No
x
Yes
Yes
Yes
No
Yes
x
Yes
Yes
Yes
Yes
Yes
Important
Important
On a tagged port that is Layer-2 trusted, Layer-3 trusted and DiffServ enabled, all multicast packets honor the ingress DSCP value.
The QoS level for control packets destined for the CPU is assigned internally to ensure timely packet processing and scaling numbers. You cannot configure the QoS level for these control packets. The system assigns the highest QoS-level to time-critical protocols.
The following table shows ingress IEEE 802.1p to QoS level mappings.
Table 2. Default ingress 802.1p to QoS mappings
Ingress IEEE 802.1p
PHB
QoS Level
Network Service Class (NSC)
0
CS0/DF
1
Standard
1
Custom
0
Custom
2
CS1/AF11
2
Bronze
3
CS2/AF21
3
Silver
4
CS3/AF31
4
Gold
5
CS4/AF41
5
Platinum
6
CS5/EF
6
Premium/EF
7
CS6/CS7
7
Network/Critical
The following table shows DSCP to internal QoS level mappings.
Table 3. Default ingress DSCP to QoS mapping
Ingress
PHB level
DSCP
(decimal)
DSCP
(binary)
DSCP
(hexadecimal)
TOS
(hexadecimal)
00
000000
00
00
1
CS0/DF
00
000000
00
00
1
DF
01
000001
01
04
1
CS0
02
000010
02
08
1
CS0
03
000011
03
0C
1
CS0
04
000100
04
10
1
CS0
05
000101
05
14
1
CS0
06
000110
06
18
1
CS0
07
000111
07
1C
1
CS0
08
001000
08
20
2
CS1
09
001001
09
24
1
CS0
10
001010
0A
28
2
AF11
11
001011
0B
2C
1
CS0
12
001100
0C
30
2
CS1
13
001101
0D
34
1
CS0
14
001110
0E
38
2
CS1
15
001111
0F
3C
1
CS0
16
010000
10
40
3
CS2
17
010001
11
44
1
CS0
18
010010
12
48
3
AF21
19
010011
13
4C
1
CS0
20
010100
14
50
3
CS2
21
010101
15
54
1
CS0
22
010110
16
58
3
CS2
23
010111
17
5C
1
CS0
24
011000
18
60
4
CS3
25
011001
19
64
1
CS0
26
011010
1A
68
4
AF31
27
011011
1B
6C
4
CS3
28
011100
1C
70
4
CS3
29
011101
1D
74
1
CS0
30
011110
1E
78
4
CS3
31
011111
1F
7C
1
CS0
32
100000
20
80
5
CS4
33
100001
21
84
1
CS0
34
100010
22
88
5
AF41
35
100011
23
8C
5
CS4
36
100100
24
90
5
CS4
37
100101
25
94
1
CS0
38
100110
26
98
5
CS4
39
100111
27
9C
1
CS0
40
101000
28
A0
6
CS5
41
101001
29
A4
5
CS4
42
101010
2A
A8
1
CS0
43
101011
2B
AC
1
CS0
44
101100
2C
B0
1
CS0
45
101101
2D
B4
1
CS0
46
101110
2E
B8
6
EF
47
101111
2F
BC
6
CS5
48
110000
30
C0
7
CS6
49
110001
31
C4
1
CS0
50
110010
32
C8
1
CS0
51
110011
33
CC
1
CS0
52
110100
34
D0
1
CS0
53
110101
35
D4
1
CS0
54
110110
36
D8
1
CS0
55
110111
37
DC
1
CS0
56
111000
38
E0
7
CS7
57
111001
39
E4
1
CS0
58
111010
3A
E8
1
CS0
59
111011
3B
EC
1
CS0
60
111100
3C
F0
1
CS0
61
111101
3D
F4
1
CS0
62
111110
3E
F8
1
CS0
63
111111
3F
FC
1
CS0
Egress mappings include:
  • QoS level to IEEE 802.1p mappings
  • QoS level to DSCP mappings
When a packet is forwarded by the switch, the software does the following:
  • Always performs 802.1p remarking before the packet egresses.
  • If the ingress port has enable-diffserv and access-diffserv enabled, then the IP packet is DSCP remarked before the packet egresses.
    If the ingress port is not configured this way, the packets are not DSCP remarked.
The following table shows egress QoS level to IEEE 802.1p mappings.
Table 4. Default egress QoS level to IEEE 802.1p mappings
QoS level
PHB
Default 1p remarking on egress
0
Custom
1
Custom
1
CS0/DF
0
Standard
2
CS1/AF11
2
Bronze
3
CS2/AF21
3
Silver
4
CS3/AF31
4
Gold
5
CS4/AF41
5
Platinum
6
CS5/EF
6
Premium/EF
7
CS6/CS7
7
Network/Critical
The following table shows QoS level to DSCP mappings.
Table 5. Default egress QoS level to DSCP mappings
Egress
QoS level
DSCP
(binary)
DSCP
(hexadecimal)
DSCP
0
000000
00
0
1
000000
00
0
2
001010
0A
10
3
010010
12
18
4
011010
1A
26
5
100010
22
34
6
101110
2E
46
7
101110
2E
46
