View a tunnel for IPv6 addresses.
You can assign an IPv6 address to a VLAN or brouter port.
To create MLT and LAG interfaces with IPv6, you must configure VLAN-based connections and you cannot use brouter ports.
You can also assign an IPv6 address through the navigation path, and through the navigation path.
- Select Tunnel.
- Select the Tunnel Config tab.
- Select IPv6 Address.
Tunnel Config Field Descriptions
Use the data in the following table to use the Tunnel Config tab.
Name |
Description |
AddressType |
Shows the address type over which the tunnel encapsulates packets. |
LocalAddress |
Configures the address of the local endpoint of the tunnel. |
RemoteAddress |
Configures the address of the remote endpoint of the tunnel. |
EncapsMethod |
Configures the tunnel mode, which is manual for manually configured tunnels. |
ID |
Configures the ID for the tunnel. |
IfIndex |
Shows the value of ifIndex that corresponds to the tunnel interface. A value of 0 indicates that the interface index has not yet been assigned. The system displays this field only on the Tunnel Config tab. |
