You can monitor or apply the same configuration changes to more than one port by using the multiple port selection function. You can use the standard menu or the shortcut menu to edit the configuration settings for multiple ports.
Tip
Tip
A selected port shows a yellow outline around the port.
  1. Select the Device Physical View tab.
  2. To select multiple ports, press Ctrl (Control), and then select the required ports.
