View stat rate limit statistics to view the total dropped packets and bytes.
- In the Device Physical View, select a port.
- Select Port.
- Select the Stat Rate Limit tab.
- Select one or more values.
- Select the type of graph to create.
Stat Rate Limit Field Descriptions
Use the data in the following table to use the Stat Rate Limit tab.
| Name | Description |
| DropPktRate | Indicates the drop packet rate. |
| DropByteRate | Indicates the drop byte rate. |
| DropTotalBytes | Indicates the total bytes dropped. |
| DropTotalPkts | Indicates the total packets dropped. |
