Use the following procedure to display information about IPFIX flows. You can display information for all IPFIX flows, or you can specify a single IPFIX flow and display additional information about that flow.
Display all IPFIX flows:
Switch:1>show ip ipfix flows
IPFIX Flows
Source Destination Source Destination Protocol In
IP IP Port Port Port
192.0.2.1 198.51.100.1 63 63 UDP 1/17
203.0.113.2 203.0.113.1 63 63 UDP RX-NNI
The following table defines parameters for the show ip ipfix flows command.
Variable |
Value |
dest-addr {A.B.C.D} |
Specifies an IP address for the flow destination. |
dest-port <1-65535> |
Specifies a value for the destination port. |
in-vlan <1-4095> |
Specifies an ingress VLAN ID for the flow. |
in-vrf <0-511> |
Specifies an ingress VRF ID for the flow. |
ip-ttl <0-255> |
Specifies the IP time-to-live (TTL) for the flow. |
protocol {udp|tcp} |
Specifies the transport protocol. |
source-addr {A.B.C.D} |
Specifies an IP address for the flow source. |
source-port <1-65535> |
Specifies a value for the source port. |
untagged |
Specifies ingress untagged flows. |
