Use the following procedure to display the next hop for the logical interface.
  1. In the navigation pane, expand Configuration > Fabric > IS-IS.
  2. Select the Logical Interfaces NextHop tab.
Logical Interfaces NextHop Field Descriptions
Use the data in the following table to use the Logical Interfaces NextHop tab.
Name
Description
Id
Shows a unique value that identifies the logical interface tunnel.
Ip
Shows a unique value that identifies the next hop IP address of the logical interface tunnel.
DestIfIndex
Shows the next hop destination interface index to reach the next hop IP of the logical interface tunnel.
DestVid
Shows the next hop destination VLAN ID to reach the next hop IP of the logical interface tunnel.
