View the Mesh Group
Configure Message Digest (MD) 5 authentication to secure control messages on the TCP connection between MSDP peers.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
- Select MSDP.
- Select the Mesh Group tab.
Mesh Group Field Descriptions
Use the data in the following table to use the Mesh Group tab.
Name |
Description |
Name |
Specifies the mesh group ID; the name of the mesh group from 1-64 characters. |
PeerAddress |
Specifies the IP address of the MSDP router that is the peer. |
