Display Port VLAN Information
Switch:1>enable Switch:1#show interfaces gigabitethernet vlan ==================================================================================================== Port Vlans ==================================================================================================== PORT DISCARD DISCARD DEFAULT VLAN PORT UNTAG DYNAMIC UNTAG FA/ NUM TAGGING TAGFRAM UNTAGFRAM VLANID IDS TYPE DEFVLAN VLANS VLANS Flex UNI ---------------------------------------------------------------------------------------------------- 1/1 disable false false 1 1 normal disable P 1 disable 1/2 enable false false 1 1,3,10 normal disable P 1,10 disable 1/3 enable false false 1 1,10,20 normal disable P disable ---------------------------------------------------------------------------------------------------- DYNAMIC VLAN Legend: P=Protocol enabled.
The following table defines parameters for the show interfaces command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
<1-4059> |
