Display global information about flap-dampening.
Switch(config)# show ip bgp flap-damp-config vrf vrf1
BGP Flap Dampening - VRF vrf1
Status - enable
PolicyName - N/A
CutoffThreshold - 1536
ReuseThreshold - 512
Decay - 2
MaxHoldDown - 180
The following table defines parameters for the show ip bgp flap-damp-config command.
Variable |
Value |
<prefix/len> |
Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32). |
vrf WORD<1–16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids WORD<0–512> |
Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
