Copy configuration and log files from an external USB device to the internal Flash memory.
Switch:1#enable
Switch:1#copy /usb/test.cfg /intflash/test.cfg
The following table defines parameters for the copy command.
Variable |
Value |
<destfile> |
Specifies the name of the configuration or log file when copied to the internal Flash memory. The destination file name must be lower case and have a file extension of .cfg or .log. For example, test.cfg or test.log. The file name, including the directory structure, can include up to 255 characters. |
<srcfile> |
Specifies the name of the configuration or log file on the USB device. For example, test.cfg or test.log. The file name, including the directory structure, can include up to 255 characters. |
