Configure community lists to specify permitted routes by using their BGP community. This list acts as a filter that matches communities or AS numbers.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
The VRF must have an RP trigger of BGP.
- Select Policy.
- Select the Community List tab.
- Select Insert.
- Configure the list as required.
- Select Insert.
Community List Field Descriptions
Use the data in the following table to use the Community List tab.
Name |
Description |
Id |
Specifies the community list. The range is 0–1024. |
MemberId |
Specifies the community list member ID. The range is 0–65535. |
Mode |
Specifies the action to take if the system selects a policy for a specific route. Select permit (allow the route) or deny (ignore the route). |
Community |
Specifies the community access list community string. |
