Configure IPv6 PIM Static RP
On IPv6 PIM BSR mechanism is not supported so static RP must be configured.
Enable IPv6 PIM-SM globally.
The following table describes the variables for the ipv6 pim static-rp command.
Variable |
Value |
WORD<0-255> |
Specifies the IPv6 address and address mask of the multicast group. When combined, the IPv6 address and address mask identify the range of the multicast addresses that the RP handles. |
WORD<0-255> |
Specifies the IPv6 address of the static RP. |
