Configure an ACE to filter IPv4 routed packets.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select IpRouted tab.
- Select Insert.
- In AclId, type the appropriate ACL ID.
- In AceId, type the appropriate ACE ID.
- RoutedOnly
- Select Insert.
IpRouted Field Descriptions
The following table describes values on the IpRouted tab.
Name |
Description |
AclId |
Specifies the ACL ID. Value range of 1 to 2048. |
AceId |
Specifies the ACE ID. Value range of 1 to 2000. |
