Perform this procedure to fragment packets larger than the IPsec tunnel maximum transmission unit (MTU) before the packets are sent for encryption.
  • Ensure IPsec is disabled on the tunnel. The administrative state must be disabled before you can enable or disable fragmentation before encryption.
  • Configure the IPsec destination IP address or enable responder mode.
By default, fragmentation before encryption is disabled.
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Enable fragmentation before IPsec encryption:
    set ipsec <1-255> fragment-before-encrypt enable
