Use the following command to display uPnP Filtering information on an IGMP-enabled interface.
View the default uPnP Filtering information on an IGMP-enabled interface:
Switch:1#show ip igmp interface vlan 2
Vlan Ip Igmp
VLAN QUERY QUERY ROBUST VERSION LAST PROXY SNOOP SNOOP SSM UPnP FAST FAST
ID INTVL MAX MEMB SNOOP ENABLE ORIGIN SNOOP FILTER LEAVE LEAVE
RESP QUERY ENABLE ENABLE ENABLE ENABLE PORTS
2 125 100 2 2 10 false false RADIUS false true false
VLAN SNOOP SNOOP DYNAMIC COMPATIBILITY EXPLICIT UPnP
ID QUERIER QUERIER DOWNGRADE MODE HOSTS FILTER
ENABLE ADDRESS VERSION TRACKING ADDRESS
2 false 0.0.0.0 enable disable disable 192.0.2.3/24
View uPnP Filtering information on an IGMP-enabled interface when uPnP Filtering is enabled and a non-default multicast group address is configured:
Switch:1(config)#show ip igmp interface vlan 2
Vlan Ip Igmp
2 false 0.0.0.0 enable disable disable 233.252.0.0/24
The following table defines parameters for the show ip igmp interface command.
Variable |
Value |
gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
vlan <1-4059> |
Specifies the VLAN. |
vrf WORD<1–16> |
Specifies the VRF by name. |
vrfids WORD<0–512> |
Specifies the VRF by VRF ID. |
