Use the following procedure to configure an aging interval for IPFIX. The aging interval determines how long a traffic flow that is no longer being received, is retained as a flow.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ip ipfix aging-interval 1d
The following table defines parameters for the ip ipfix aging-interval command.
Variable |
Value |
<100ms | 1s | 10s | 60s | 10m | 30m | 1h |10h |1d> |
Specifies, in seconds, minutes, hours, or days, the flow record aging interval. The aging interval determines how long a traffic flow that is no longer being received is retained as a flow. The default is 10 seconds. |
