Configure an IPv6 Prefix List
Use IPv6 prefix lists to allow or deny specific IPv6 route updates. A prefix list policy specifies route prefixes to match. When there is a match, the route is used.
You configure prefix lists on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode.
Create an IPv6 prefix list:
Switch:1<config>#ipv6 prefix-list list4 2001:DB8::/32 ge 32 le 32
To rename the list:
Switch:1<config>#ipv6 prefix-list list4 name list5
Use the data in the following table to use the ipv6 prefix-list command.
Variable |
Value |
<WORD 1–64> |
Specifies the IPv6 prefix-list name. |
<WORD 1–256> |
Specifies the IPv6 prefix and length. |
ge <0–128> |
Specifies the minimum length to match. Lower bound and higher bound mask lengths together can define a range of networks. |
id <1-2147483647> |
Specifies the Prefix list ID. |
le <0–128> |
Specifies the maximum length to match. Lower bound and higher bound mask lengths together can define a range of networks. |
name <WORD 1–64> |
Names the prefix list. The default value is none. |
Use the data in the following table to use the show ipv6 prefix-list command.
Variable |
Value |
<WORD 1–256> |
vrf WORD<1-16> |
Specifies the name of the VRF. |
vrfids WORD<0-512> |
Specifies the ID of the VRF and is an integer in the range of 0–512. |
WORD<1-64> |
Specifies a prefix list, by name, to use for the command output. |
