Configure the metrics that OSPF uses for different link speeds. The lower the metric, the more likely that OSPF chooses the link to route an OSPF packet.
  • Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
  1. In the navigation pane, expand Configuration > IP
  2. Select OSPF.
  3. Select the General tab.
  4. Change the metric for one or all of the following:
    • 10MbpsPortDefaultMetric
    • 100MbpsPortDefaultMetric
    • 1000MbpsPortDefaultMetric
    • 10000MbpsPortDefaultMetric
    • 25000MbpsPortDefaultMetric
    • 40000MbpsPortDefaultMetric
    • 100000MbpsPortDefaultMetric
  5. Select Apply.
