Configure ACE IP destination address entries to have the filter look for specific destination IP addresses.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select IP.
- Select the Destination Address tab.
- Select Insert.
- Specify the operation type.
- In the IPAddr box, enter the destination IP address.
- Select Insert.
Destination Address Field Descriptions
Use the data in the following table to use the Destination Address tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits. |
IPAddr |
Specifies the destination IP address. |
OperMask |
Specifies the mask value for the destination IP address. |
