Configure the system flags to enable or disable flags for specific configuration settings.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Chassis.
  3. Select the System Flags tab.
  4. Select the system flags you want to activate.
  5. Clear the system flags you want to deactivate.
  6. Select Apply.
    Important
    Important
    After you change certain configuration parameters, you must save the changes to the configuration file.
System Flags Field Descriptions
Use the data in the following table to use the System Flags tab.
Name
Description
EnableAccessPolicy
Activates access policies. The default is disabled.
ForceTrapSender
Configures circuitless IP as a trap originator. The default is disabled.
ForceIpHdrSender
If you enable Force IP Header Sender, the system matches the IP header source address with SNMP header sender networks. The default is disabled.
AuthSuccessTrapEnable
Enables the system to send the authentication success trap, rcnAuthenticationSuccess. The default is disabled.
MrouteStrLimit
Enable or disable Mroute stream limit in system. The default is disabled.
DataPathFaultShutdownEnable
Enable or disable data path fault shutdown. The default is enabled.
PingTracerouteContextType
Configures the default context for executing ping commands and traceroute commands. The default is grt.
UdpSrcByVirtualIpEnable
Enables or disables virtual IP as the User Datagram Protocol (UDP) source. The default is disabled.
ForceTopologyIpFlagEnable
Activates or disables the flag that configures the CLIP ID as the topology IP. Values are true or false.
CircuitlessIpId
Uses the CLIP ID as the topology IP.
