Assign an IPv6 address to the interface.
Enable routing globally.
Change the VRF instance as required to configure VRRP notification control on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
Perform this procedure to configure VRRP notification control.
- Select VRRP.
- Select the Globals tab.
- Select enabled.
- Select Apply.
Use the data in the following table to use the Globals tab.
Name | Description |
NotificationCntrl | Indicates whether the VRRP-enabled router generates SNMP traps for events.
The default is enabled. |
