Use this task to configure a DHCP Client on a management interface.
- Select Mgmt.
- Select the Dhcp tab.
- In Client, select an option to configure the DHCP Client.
- Select Apply.
Dhcp Field Descriptions
Use the data in the following table to use the Dhcp tab.
Name |
Description |
Client Note:
Exception: oob and cycle not supported on 5320 Series |
Specifies the DHCP client configuration:
ClientPreferredInterface |
Shows the DHCP Client preferred management interface when in cycle mode. On reboot, the system first attempts to aquire a DHCP IP address on the preferred interface. |
