Configure OVSDB Replication
Use the following procedure to configure OVSDB replication to support vIST.
You must enable VXLAN Gateway Full Interworking Mode on the switch.
You must configure an OVSDB managed interface on the switch.
You must configure and enable OVSDB protocol support for VXLAN Gateway on the switch.
You must have at least two NVCs configured to communicate on the managed interface network.
The following is an example configuring OVSDB replication to support
VIST.
SWITCH:1>enable SWITCH:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. SWITCH:1(config)#ovsdb SWITCH:1(config-ovsdb)#replication peer-ip 192.0.2.3 local-ip 192.0.2.2
Variable definitions
Use the data in the following table to use the replication command.
Variable |
Value |
peer-ip <A.B.C.D> |
Specifies the IP address of the secondary controller for OVSDB replication support. |
local-ip <A.B.C.D> |
Specifies the IP address of the primary controller for OVSDB replication support. |
