Configure OSPF NBMA Neighbors
Configure NBMA neighbors so that the interface can participate in designated router election. All OSPF neighbors that you manually configure are NBMA neighbors.
Enable OSPF globally.
Ensure that the interface uses an IP address.
Ensure that the interface is NBMA.
You configure OSPF NBMA neighbors on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode and the prefix ip ospf. The VRF must have an RP Trigger of OSPF. Not all parameters are configurable on non0 VRFs.
Create an NBMA OSPF neighbor.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router ospf Switch:1(config-ospf)#neighbor 198.51.100.2 priority 10
Variable definitions
The following table defines parameters for the neighbor command.
Variable |
Value |
{A.B.C.D} |
Identifies an OSPF area in IP address format a.b.c.d. |
priority <0-255> |
Changes the priority level of the neighbor. |
UThe following table defines parameters for the show ip ospf neighbors command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
