Configure the calendar time in the form of month, day, year, hour, minute, and second.
Log on as rwa to perform this procedure.
Configure the date and time, and then verify the configuration.
Switch:1>enable Switch:1#clock set 01222024163312 Switch:1#show clock Mon Jan 22 16:33:12 2024 EDT
Use the data in the following table to use the clock set command.
Variable |
Value |
MMddyyyyhhmmss |
Specifies the date and time in the format month, day, year, hour, minute, and second. |
