View all of the ACE IPv6 entries associated with an ACL.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation pane, expand Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select the appropriate ACL.
  5. Select ACE.
  6. Select the appropriate ACE.
  7. Select IPv6.
  8. Select the IPv6 tab.
IPv6 Field Descriptions
Use the data in the following table to use the IPv6 tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
SrcAddrList
Shows the source IP address.
SrcAddrOper
Shows the operators for the ACE IP source address.
DstAddrList
Shows the destination IP address.
DstAddrOper
Shows the operators for the ACE IP destination address.
NxtHdrNxtHdr
Shows the next header of the IPv6 header.
NxtHdrOper
Shows the operators for the next header.
TrafficClsOper
Shows the operators for the traffic class.
TrafficCls
Shows the traffic class attribute of the IPv6 header.
SrcAddrMask
Shows the mask value for the source IP address.
DstAddrMask
Shows the mask value for the destination IP address.
