Use the following procedure to configure IS-IS interface level parameters. SPBM uses IS-IS to discover network topology, build shortest path trees between network nodes, and communicate network information in the control plane.
- Select IS-IS.
- Select the Interfaces Level tab.
- Configure the IS-IS interface level parameters.
- Select Apply.
Interfaces Level Field Descriptions
Use the data in the following table to use the Interfaces Level tab.
Name |
Description |
Index |
The identifier of this circuit, unique within the Intermediate System. This value is for SNMP Indexing purposes only and need not have any relation to any protocol value. |
Level |
Specifies the router type globally:
The default value is l1. |
ISPriority |
Specifies an integer sub-range for IS-IS priority. The default is 64. |
HelloTimer |
Configures the level 1 hello interval. Specifies the maximum period, in milliseconds, between IS-IS Hello Packets (IIH) PDUs on multiaccess networks at this level for LANs. The value at Level1 is used as the period between Hellos on Level1/Level2 point to point circuits. Setting this value at Level 2 on an Level1/Level2 point-to-point circuit results in an error of InconsistentValue. The default value is 9000 milliseconds or 9 seconds. |
HelloMultiplier |
Configures the level 1 hello multiplier. The default value is 3 seconds. |
DRHelloTimer |
Indicates the period, in milliseconds, between Hello PDUs on multiaccess networks when this Intermediate System is the Designated Intermediate System. The default is 3. |
