Perform this procedure to configure the Level 1 remote Intermediate-System-to-Intermediate-System (IS-IS) designated router priority to the specified value.
Configuring the remote IS-IS designated router priority for port 1/4:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#isis remote l1-dr-priority 1
The following table defines parameters for the isis remote l1-dr-priority command.
Variable | Value |
<0-127> |
Specifies the level 1 remote Intermediate-System-to-Intermediate-System (IS-IS) designated router priority value. The default value is 64. |
