Perform this procedure to verify that the software files are downloaded properly to the switch. The MD5 checksum for each release is available from the Extreme Networks Support portal.
Download the MD5 checksum to an intermediate workstation or server where you can open and view the contents.
Download the image file to the switch.
Calculate and verify the MD5 checksum after you download software files.
View the contents of the MD5 checksum on the workstation or server:
9e8e4356ec44661514cd142e933dca59 5420.8.4.0.0_edoc.tar 4602bf5adbc0c31c0e5f5d38209d7b87 5420.8.4.0.0_mib_sup.txt 25be1902e954e3140d1072562c926d4b 5420.8.4.0.0_mib.txt 09d06a9dbbfdaa07cabd2000556d5d2b 5420.8.4.0.0_mib.zip 8e23c6632b5b7a9ec134418348baebea 5420.8.4.0.0_oss-notice.html d83cd61e0b115c83aca0c52c9dd5eb0e 5420.8.4.0.0.voss eb86e5991d8ce2a69b21510b993e0727 restconf_yang.tgz 561a5b566c42b68cc4b1fc3b1e71cf70 VOSSv840_HELP_EDM_gzip.zip
Calculate the MD5 checksum for the file on the switch:
Switch:1>ls *.voss Listing Directory /intflash: -rw-r--r-- 1 0 0 94195267 Dec 13 14:42 5420.8.4.0.0.voss Switch:1>file-checksum md5 5420.8.4.0.0.voss MD5 (5420.8.4.0.0.voss) = d83cd61e0b115c83aca0c52c9dd5eb0e
The following table defines parameters for the file-checksum md5 command:
Variable |
Value |
WORD<1-99> |
Specifies the file name. |
