You must disable the IPsec administrative state on the tunnel before you can remove IPsec configuration.
Perform this procedure to delete the configuration of a specific IPsec tunnel on Fabric IPsec Gateway Virtual Machine (VM).
Delete configuration on IPsec tunnel ID 2:
Switch:1> enable Switch:1# virtual-service figw console Connected to domain figw Escape character is ^Y <cr> FIGW>delete ipsec 2 admin-state enable FIGW>delete ipsec 2 auth-key FIGW>delete ipsec 2 tunnel-name FIGW>delete ipsec 2 fragment-before-encrypt enable
The following table defines parameters for the delete ipsec command.
Variable | Value |
<1-255> |
Specifies the unique ID of the configured IPsec tunnel. |
admin-state enable |
Disables the IPsec status on the specific IPsec tunnel. |
auth-key |
Deletes the authentication key that you configure on the specific IPsec tunnel. |
encryption-key-length |
Resets the encryption key length for the specific IPsec tunnel to its default value, that is 128 bit. |
fe-tunnel-dest-ip |
Deletes the destination IP address that you configure on the Fabric Extend (FE) tunnel. |
fragment-before-encrypt enable |
Disables the fragmentation of packets before IPsec encryption on the tunnel. By default, fragmentation before encryption is disabled. |
ipsec-dest-ip |
Deletes the destination IP address that you configure on the IPsec tunnel. |
mtu |
Resets the Maximum Transmission Unit (MTU) value for the specific IPsec tunnel to the MTU value configured globally. |
responder-only |
Deletes the mode that you configure for the IPsec session in FE tunnel. |
tunnel-name |
Deletes the name that you configure for the IPsec tunnel. |
egress-shaping-rate |
Deletes the egress shaping rate for the IPsec tunnel. |
