Perform this procedure to display SPBM IPv6 unicast Forwarding Information Base (FIB).
Switch:1>show isis spbm ipv6-unicast-fib ==================================================================================================================== SPBM IPv6-UNICAST FIB ENTRY INFO ==================================================================================================================== VRF Dest OUTGOING SPBM PREFIX METRIC IP ROUTE VRF ISID ISID Destination NH BEB VLAN INTERFACE COST COST TYPE PREFERENCE AREA AREA-NAME -------------------------------------------------------------------------------------------------------------------- GRT - - 00:16:ca:23:73:df el2 10 1/22 10 1 Internal 7 HOME area-9.00.02 GRT - 11 00:16:ca:23:73:df esp 20 1/22 10 1 Internal 7 HOME area-9.00.02 vrf1 11 100 00:18:b0:bb:b3:df el2 10 1/22 10 1 External 7 HOME area-9.00.02 vrf1 11 11 00:14:c7:e1:33:e0 ess 20 1/22 10 1 External 7 HOME area-9.00.02 ------------------------------------------------------------------------------------------------------------------- Home: Total number of SPBM IPv6-UNICAST FIB entries 4 Remote: Total number of SPBM IPv6-UNICAST FIB entries 0 --------------------------------------------------------------------------------------------------------------------
The following table defines parameters for the show isis spbm ipv6-unicast-fib command.
Variable |
Value |
all |
Displays all IS-IS SPBM IPv6 unicast Fowarding Information Base (FIB) information for all VRFs. |
home |
Displays the IS-IS SPBM IPv6 unicast FIB information that the system configures in the home area. |
id <1-16777215> |
Displays IS-IS SPBM IPv6 unicast FIB information by I-SID ID. |
remote |
Displays the IS-IS SPBM IPv6 unicast FIB information that the system configures in the remote area. |
spbm-nh-as-mac |
Displays the next hop BMAC of the IPv6 unicast FIB entry. |
