Perform this task to run a VM command from EDM. To include spaces in the syntax, include the text string in quotation marks (").
  1. In the navigation pane, expand Configuration > Serviceability.
  2. Select the Virtual Service.
  3. Select the Globals tab.
  4. In ScalarsName, type a virtual service name.
  5. In ExecuteCommand, type the ls command for the VM configs directory. For example, "ls /home/rwa/configs".
  6. In FigwCli, type a command to send it to the Fabric IPsec Gateway. For more information about Fabric IPsec Gateway commands, see Fabric Engine Command References.
  7. Select Apply.
