View Network Host Statistics
View network host statistics to see Layer 3 traffic statistics for each host. The network layer host MIB monitors traffic packets in and out of hosts based on the network layer address.
- Select Network Layer Host.
- Select the Network Host Stats tab.
Network Host Stats Field Descriptions
Use the data in the following table to use the Network Host Stats tab.
Name |
Description |
LocalIndex |
Shows a unique identifier for the entry in the table. |
HostAddress |
Shows the host address for this entry. |
InPkts |
Shows the number of packets without errors transmitted to this address. This value is the number of link-layer packets so a single, fragmented network-layer packet can increment the counter several times. |
OutPkts |
Shows the number of packets without errors transmitted by this address. This value is the number of link-layer packets so a single, fragmented network-layer packet can increment the counter several times. |
InOctets |
Shows the number of octets transmitted to this address, excluding octets in packets that contained errors. This value counts octets in the entire packet that contained the protocol, not just the particular protocol frames. |
OutOctets |
Shows the number of octets transmitted by this address, excluding octets in packets that contained errors. This value counts octets in the entire packet that contained the protocol, not just the particular protocol frames. |
CreateTime |
Shows the value of the sysUpTime when the entry was last activated. |
