Use this procedure to map a port to a RA Guard or DHCPv6 Guard policy, DHCPv6 Guard or RA Guard statistics.
- Select FHS.
- Select the Port Policy Mapping tab.
- Select Insert.
- Configure the parameters for the port policy mapping.
- Select Insert.
- Optional: Select Refresh to update the results.
Port Policy Mapping Field Descriptions
Use the data in the following table to use the Insert Port Policy Mapping dialog box.
Name |
Description |
IfIndex |
Specify the port. |
DHCPv6GuardPolicyName |
Enter an already-created DHCPv6 Guard policy name to map it with the port. |
RAGuardPolicyName |
Enter an already-created RA Guard policy name to map it with the port. |
Dhcpv6gDeviceRole |
Select server or client configuration. The default is server. |
RagDeviceRole |
Select host or router configuration. The default is router. |
