View Statistics for a VRF
View VRF statistics to ensure the instance is performing as expected.
- Select VRF.
- Select the VRF tab.
- Select a VRF.
- Select the Stats button.
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
Name |
Description |
StatRouteEntries |
Specifies the number of routes for this VRF. |
StatFIBEntries |
Specifies the number of Forwarding Information Base (FIB) entries for this VRF. |
