CFM Configuration Example
This section provides a configuration example for Connectivity Fault Management (CFM).
The following sections show the steps required to configure CFM.
The following commands are not supported on all hardware platforms:
  • cfm maintenance-domain
  • cfm maintenance-association
  • vlan nodal-mip-level
Switch A
MAINTENANCE-DOMAIN CONFIGURATION
cfm maintenance-domain "spbm" index 1 maintenance-level 6
MAINTENANCE-ASSOCIATION CONFIGURATION
cfm maintenance-association "spbm" "2" index 1
cfm maintenance-association "spbm" "3" index 2
MAINTENANCE-ENDPOINT CONFIGURATION
cfm maintenance-endpoint "spbm" "2" 1 state enable
cfm maintenance-endpoint "spbm" "3" 1 state enable
VLAN NODAL MEP/MIP CONFIGURATION
vlan nodal-mep 2 spbm 2 1
vlan nodal-mip-level 2 6
vlan nodal-mep 3 spbm 3 1
vlan nodal-mip-level 3 6
Switch B
cfm maintenance-domain spbm index 1 maintenance-level 6
cfm maintenance-endpoint "spbm" "2" 2 state enable
cfm maintenance-endpoint "spbm" "3" 2 state enable
vlan nodal-mep 2 spbm 2 2
vlan nodal-mep 3 spbm 3 2
CFM Sample Output
The following sections show sample CFM output.
L2ping can use the system ID or the router name. The following example shows a case where the VLAN and MAC are given.
show isis adjacencies
Switch:1# show isis adjacencies
                                ISIS Adjacencies
INTERFACE L STATE  UPTIME      PRI  HOLDTIME   SYSID          HOST-NAME     STATUS   AREA  AREA-NAME
Port1/3   1  UP    00:37:37    127   22      0014.0dbf.a3df   Switch-Lab1   ACTIVE   HOME  area-9.00.02
Port1/19  1  UP    1d 05:09:16 127   25      0014.0da2.b3df   Switch-Lab2   BACKUP   HOME  area-9.00.02
 Home:   2 out of 2 interfaces have formed an adjacency
 Remote: 0 out of 0 interfaces have formed an adjacency
l2 ping with vlan
Switch:1# l2 ping vlan 500 mac 00.14.0d.bf.a3.df
Please wait for l2ping to complete or press any key to abort
----00:14:0d:bf:a3:df    L2 PING Statistics----  0(68) bytes of data
1 packets transmitted, 0 packets received,   100.00% packet loss
l2 ping with vlan
Switch:1# l2 ping vlan 500 routernodename MONTI0
----00:14:0d:a2:b3:df    L2 PING Statistics----  0(68) bytes of data
1 packets transmitted, 1 packets received,  0.00% packet loss
  round-trip (us)        min/max/ave/stdv =  26895/26895/26895.00/ 0.00
l2 traceroute with vlan
Switch:1# l2 traceroute vlan 500 routernodename MONTI0
Please wait for l2traceroute to complete or press any key to abort
l2traceroute to MONTI0  (00:14:0d:a2:b3:df),  vlan 500
0    PETER4         (00:15:9b:11:33:df)
1    MONTI0          (00:14:0d:a2:b3:df)
l2 tracetree with vlan
Switch:1# l2 tracetree 500 1
Please wait for l2tracetree to complete or press any key to abort
l2tracetree to 53:55:10:00:00:01, vlan 500 i-sid 1 nickname 5.55.10 hops 64
1   PETER4        00:15:9b:11:33:df -> MONTI0        00:14:0d:a2:b3:df
2   MONTI0        00:14:0d:a2:b3:df -> LEE2          00:15:e8:b8:a3:df
l2 ping with IP address
You can also use L2ping and L2traceroute with an IP address. The following outputs show examples using an IP address.
Switch:1# l2 ping ip-address 192.0.2.10
L2 PING  Statistics : IP 192.0.2.10, paths found 1, paths attempted 1
TX    RX    PERCENT  ROUND TRIP TIME
VLAN NEXT HOP                               PKTS  PKTS  LOSS     MIN/MAX/AVE (us)
500  SHAMIM        (00:1a:8f:08:53:df)  1     0     100.00%  0/0/0.00
l2 ping with IPv6 address
Switch:1# l2 ping ip-address 49:0:0:0:0:0:0:11
L2 PING  Statistics : IP 49:0:0:0:0:0:0:11, paths found 1, paths attempted 1
41   SHAMIM            (00:49:00:01:00:11)  1     1       0.00%  11876/11876/11876.00
l2 traceroute with IP address
Switch:1# l2 traceroute ip-address 192.0.2.10
Please wait for l2trace to complete or press any key to abort
L2 Trace  Statistics : IP 192.0.2.10, paths found 1
SHAMIM  (00:1a:8f:08:53:df),  vlan 500
l2 traceroute with IPv6 address
Switch:1# l2 traceroute ip-address 49:0:0:0:0:0:0:11
L2 Trace  Statistics : IP 49:0:0:0:0:0:0:11, paths found 1
SHAMIM  (00:49:00:01:00:11),  vlan 41
0    4K-DUT7             (00:49:00:01:00:17)
1    9k-2             (00:49:00:01:00:92)
2    8K-1             (00:49:00:08:00:81)
3    4K-DUT1             (00:49:00:01:00:11)
show cfm maintenance-domain
Switch:1#show cfm maintenance-domain
                         Maintenance Domain
Domain Name             Domain Index    Level Domain Type
md1                     99              3     NONE
 Total number of Maintenance Domain entries: 1.
show cfm maintenance-association
Switch:1#show cfm maintenance-association
                         Maintenance Association Status
Domain Name            Assn Name              Domain Idx  Assn Idx
md1                    ma1                    1           98
 Total number of Maintenance Association entries: 1.
                         Maintenance Association config
md1                    ma1
 Total number of MA entries: 1.
show cfm maintenance-endpoint
Switch:1#show cfm maintenance-endpoint
                         Maintenance Endpoint Config
DOMAIN                 ASSOCIATION            MEP  ADMIN
NAME                   NAME                   ID
md1                    ma1                    1    enable
 Total number of MEP entries: 1.
                         Maintenance Endpoint Service
DOMAIN_NAME            ASSN_NAME              MEP_ID TYPE    SERVICE_DESCRIPTION
md1                    ma1                    1      unused
show vlan nodal-mep
Switch:1#show vlan nodal-mep
                                 Vlan Nodal Mep
VLAN_ID    DOMAIN_NAME.ASSOCIATION_NAME.MEP_ID
1
2
3
4          md1.ma1.1
5
6
7
8
9
10
11
12
13
14
show vlan nodal-mip-level
Switch:1#show vlan nodal-mip-level
                              Vlan Nodal Mip Level
VLAN_ID    NODAL_MIP_LEVEL_LIST
1
2
3
4          6
5
6
7
8
9
10
11
12
13
14
