Create NTP Restrict Entries
Perform the following procedure to configure the NTP restrict capability for a specific IPv4 or IPv6 address(es), which means the switch permits NTP traffic flow from the specified IP addresses only. By default the NTP restrict capability is disabled.
  • You can configure a maximum of 128 NTP Restrict entries (IPv4 or IPv6 addresses).
  • 0.0.0.0/0 or ::/0 NTP restrict entries are equivalent to no NTP restrict rules configured.
    enable
    configure terminal
  2. Configure a specific NTP restrict IP address:
    ntp restrict WORD<0-255>
  3. Verify the restricted IP address:
    show ntp restrict
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ntp restrict 192.0.0.0
Switch:1(config)#show ntp restrict
                            NTP Restrict Information
TYPE     ADDRESS                                    MASK/PREFIX LEN
IPv4     192.0.0.0                                    23
The following table defines parameters for the ntp restrict command:
Variable
Value
WORD<0-255>
Specifies the IPv4 or IPv6 address.
Note:
You can configure a maximum of 128 IPv4 and IPv6 addresses in the NTP restrict list.
