Change the VRF instance as required to view TCP connections information on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
Perform this procedure to view the status of connections that traverse your switch.
- Select TCP/UDP.
- Select the TCP Connections tab.
TCP Connections Field Descriptions
Use the data in the following table to use the TCP Connections tab.
Name | Description |
LocalAddressType |
Displays the type (IPv6 or IPv4) for the address in the LocalAddress field. |
LocalAddress |
Displays the IPv6 address for the TCP connection. |
LocalPort |
Displays the local port number for the TCP connection. |
RemAddressType |
Displays the type (IPv6 or IPv4) for the remote address of the TCP connection. |
RemAddress |
Displays the IPv6 address for the remote TCP connection. |
RemPort |
Displays the remote port number for the TCP connection. |
State |
Displays an integer that represents the state for the
connection:
Process |
Displays the process ID for the system process associated with the TCP connection. |
