Use the Port Access Entity (PAE) Port Table to display system-level information for each port the PAE supports. An entry display in this table for each port of this system.
- Select 802.1X - EAPOL.
- Select the EAP Security tab.
EAP Security Field Descriptions
Use the data in the following table to use the EAP Security tab.
Name |
Description |
PortNumber |
Indicates the port number associated with this port. |
PortCapabilties |
Indicates the capabilities of this PAE port.
PortVirtualPortsEnable |
Displays the status of the Virtual Ports function for the real port as True or False. |
PortCurrentVirtualPorts |
Displays the current number of virtual ports running in the port |
PortAuthenticatorEnable |
Displays the status of the Authenticator function in the Port Access Entity (PAE) as True or False. |
PortSupplicantEnable |
Displays the Supplicant function in the Port Access Entity (PAE) as True or False. |
AllowNonEapHost |
Displays the status if the system is enabled to allow hosts that do not participate in 802.1X authentication to get network access. |
Status |
Displays the authentication status for this port. The default is forceAuthorized. |
MultiHostMaxClients |
Indicates the value representing the maximum number of supplicants allowed to get authenticated on the port. |
GuestVlanId |
Specifies the VLAN to be used as a Guest VLAN. Access to unauthenticated hosts connected to this port is provided through this VLAN. 0 indicates that Guest VLAN is not enabled for this port. |
FailOpenVlanId |
Specifies the Fail Open VLAN ID for the port. If the switch declares the RADIUS servers unreachable, then all new devices are allowed access into the configured Fail Open VLAN. 0 indicates that Fail Open VLAN is not enabled for this port. |
NonEapMaxClients |
Indicates the maximum number of non-EAPoL authentication MAC addresses allowed on this port. Zero indicates that non-EAPol authentication is disabled for this port. |
EapMaxClients |
Indicates the maximum number of EAPoL authentication MAC addresses allowed on this port. Zero indicates that EAPol authentication is disabled for this port. |
MultiHostSingleAuthEnabled |
Indicates that the unauthenticated devices can access the network only after an EAP or NEAP client is successfully authenticated on the port. The VLAN to which the devices are allowed access is the authenticated client's VLAN. The default is false. |
ProcessRadiusCOAPackets |
Specifies whether to process any RADIUS requests-server packets that are received on this port. |
PortGuestIsid |
Specifies the I-SID to be used as a Guest I-SID. Access to unauthenticated hosts connected to this port is provided through this I-SID. 0 indicates that Guest I-SID is not enabled for this port. |
FailOpenIsid |
Specifies the Fail Open I-SID for the port. If the switch declares the RADIUS servers unreachable, then all new devices are allowed access into the configured Fail Open I-SID. 0 indicates that Fail Open I-SID is not enabled for this port. |
FlexUniStatus |
Displays the Flex-UNI status for the port. |
AdminTrafficControl |
Specifies the Administrative Traffic Control for the port. The default is inOut. |
OperTrafficControl |
Displays the Operating Traffic Control for the port. |
LldpAuthEnabled |
Specifies if LLDP Authentication is enabled. The default is 0 (disabled). |
PortOrigin |
Displays the Port Origin configuration status for the port. |
DynamicMHSAEnabled |
Displays the Dynamic MHSA status for the port. |
TrafficControlOrigin |
Specifies the origin of Traffic Control configuration on the port. The supported values are:
ReauthOrigin |
Specifies the origin of EAPOL reauthentication configuration on the port, either manually configured through CLI or dynamically configured through RADIUS. |
ReauthPeriodOrigin |
Specifies the origin of EAPOL reauthentication period configuration on the port, either manually configured through CLI or dynamically configured through RADIUS. |
