Configure a protocol ACE
Configure a protocol ACE to filter on the source port, destination port, ICMP and ICMPv6 message type, or TCP flags.
For IPv6 filters, you must configure next header to configure the protocol attributes.
The ACL exists.
The ACE exists.
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.
Specify ICMP packets:
Switch:1(config)#filter acl ace protocol 1 12 icmpv6-msg-type eq echoRequest
                                 32 (decimal)  |
                                 16 (decimal  |
                                 8 (decimal)  |
                                 4 (decimal)  |
                                 2 (decimal)  |
                                 1 (decimal)  |
                                 Urgent  |
                                 Ack  |
                                 Push  |
                                 Reset  |
                                 Syn  |
                                 Fin  |
Configure an ACE for TCP flags attributes: Example 1
The mask is set for an ‘ack‘ tcp flag bit regardless of whether any other tcp flag bits are also set:
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask ack ? <0-0x3F | 0-63> Mask value <Hex | Decimal>: This six bit mask is a reverse mask where 0:care about, 1:do not care about
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask ack 0x2f Hex Value 20 10 8 4 2 1 TCP Flags _ ack _ _ _ _ Binary Value 1 0 1 1 1 1 or in hex = 0x2F
Configure an ACE for TCP flags attributes: Example 2
A packet will match this filter if the 3 tcpflag bits are set in the tcp header (and only those 3 bits).
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags eq ?
WORD<1-50> Tcp flags
{none | fin | syn | rst | push | ack | urg | undefined}
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags eq syn,push,urg
You can configure a functionally equivalent filter with the mask operator as follows:
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask syn,push,urg 0x0
Configure an ACE for TCP flags attributes: Example 3
The mask operator provides more flexibility. For example a packet will match the following filter if the 'syn,push,urg' tcpflag bits are set, regardless of whether any other tcpflag bits are also set:
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask syn,push,urg ? <0-0x3F | 0-63> Mask value <Hex | Decimal>: This six bit mask is a reverse mask where 0:care about, 1:do not care about
Switch:1(config)#filter acl ace protocol 1 1 tcp-flags mask syn,push,urg 0x15
Configure an ACE for ICMP message type: Example 4
filter acl 1 type inPort name "ICMP_TRAFFIC_FILTER" filter acl port 1 1/3 filter acl ace 1 1 filter acl ace action 1 1 deny count filter acl ace ethernet 1 1 ether-type eq ip filter acl ace ip 1 1 src-ip mask 194.183.100.64 0.0.0.15 filter acl ace ip 1 1 dst-ip eq 146.97.137.42 filter acl ace ip 1 1 ip-protocol-type eq icmp filter acl ace protocol 1 1 icmp-msg-type eq echo-request filter acl ace 1 1 enable filter acl ace 1 2 filter acl ace action 1 2 deny count filter acl ace ethernet 1 2 ether-type eq ip filter acl ace ip 1 2 src-ip mask 194.183.100.64 0.0.0.15 filter acl ace ip 1 2 dst-ip eq 146.97.137.42 filter acl ace ip 1 2 ip-protocol-type eq icmp filter acl ace protocol 1 2 icmp-msg-type eq echoreply filter acl ace 1 2 enable
Use the data in the following table to use the filter acl ace protocol command.
                             Variable  |
                             Value  |
                             {0-0x3F}  |
                             Specifies the mask value.  |
                             <1-2000>  |
                             Specifies the ACE ID.  |
                             <1-2048>  |
                             Specifies the ACL ID.  |
                             WORD<1–50>  |
                             Specifies one or more TCP flags—none, fin (finish connection), syn (synchronize), rst (reset connection), push, ack (acknowledge), urg (urgent), and undefined.  |
                             WORD<1–60>  |
                             Specifies the destination port: (0–65535), or echo, ftpdata, ftpcontrol, ssh, telnet, dns, http, hdot323, bootpServer, bootpClient, tftp, rtp, rtcp, or undefined.  |
                             WORD<1–200>  |
                             Specifies the ICMP message type: Icmpmsg type (0–255), or echoreply, destunreach, sourcequench, redirect, echo-request, routeradv, routerselect, time-exceeded, param-problem, timestamp-request, timestamp-reply, addressmask-request, addressmask-reply, or traceroute.  |
                             WORD<1–200>  |
                             Specifies the ICMPv6 message type: Icmpmsg type (0-255), or destUnreach, pktTooBig, timeExceeded, paramProblem, echoRequest, echoReply, mcastListenReq, mcastListenRpt, mcastListenDone, routerSolicit, routerAdvert, neighborSolicit, neighborAdvert, redirectMsg, nodeInfoReq, nodeInfoRsp, or v2McastListenRpt.  |
                             WORD<1–256>  |
                             Specifies the mask parameter, {0-0xFFFF}.  |
                             WORD<0–65535>  |
                             Specifies the source port (0–65535).  |
