View BGPv6 Routes
Display information about BGPv6 routes.
The following table defines parameters for the show bgp ipv6 route command.
Variable |
Value |
[<WORD 1-256>] |
Specifies the IPv6 prefix and the prefix length (must be an integer value between 0 and 128). |
community <enable|disable> |
Enables or disables the display of community attributes. |
ipv6 <WORD 1-256>] |
Specifies an IPv6 address. |
longer-prefixes |
Shows long prefixes. The longer-prefixes indicate the mask length from any specified prefix to 128 (for example, show from prefix X:X::X:X/len to X:X::X:X/ 128). |
vrf |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids |
Specifies a range of VRFs by ID number (the ID ranges from 0–255). |
