Table 1. Entity MIB product support
Feature
Product
Release introduced
Entity MIB - Physical Table
5320 Series
Fabric Engine 8.6
5420 Series
VOSS 8.4
5520 Series
VOSS 8.2.5
5720 Series
Fabric Engine 8.7
7520 Series
Fabric Engine 8.10
7720 Series
Fabric Engine 8.10
VSP 4900 Series
VOSS 8.1
VSP 7400 Series
VOSS 8.0
Entity MIB enhancements and integration for the following:
  • Physical Table
  • Alias Mapping Table
  • Physical Contains Table
  • Last Change Time object
5320 Series
Fabric Engine 8.6
5420 Series
VOSS 8.4
5520 Series
VOSS 8.2.5
5720 Series
Fabric Engine 8.7
7520 Series
Fabric Engine 8.10
7720 Series
Fabric Engine 8.10
VSP 4900 Series
VOSS 8.1
VSP 7400 Series
VOSS 8.0
Entity MIB - Logical Table includes the following logical interface entities:
  • VLANs
  • MLTs
  • Circuitless IP (CLIP)
  • Fabric Extend interfaces (logical layer 2 and layer 3 IS-IS interfaces)
5320 Series
Fabric Engine 8.6
5420 Series
VOSS 8.4
5520 Series
VOSS 8.4
5720 Series
Fabric Engine 8.7
7520 Series
Fabric Engine 8.10
7720 Series
Fabric Engine 8.10
VSP 4900 Series
VOSS 8.4
VSP 7400 Series
VOSS 8.4
The Entity MIB – Physical Table assists in the discovery of functional components on the switch. The Entity MIB – Physical Table supports a physical interface table that includes information about the chassis, power supply, fan, I/O cards, console, and management port.
Some hardware platforms support removable interface modules while others offer a fixed configuration. The names used for these modules can vary depending on the hardware platform.
The following table identifies the entity index range for the switch components.
Table 2. Entity index range for switch components
Component
Entity index range
Chassis
1
Power supply slot
3 to 8
Fan tray and fan slot
9 to 16
I/O slot
17 to 30
SF Slot
31 to 36
I/O card or module
37 to 50
SF Card
51 to 56
Console port
57
Console port 2
58
Management port
64
Management port 2
65
Power supply
68 to 73
Fan tray
74 to 81
Fan module
82 to 105
Port
192 to 1023
Pluggable Module and Sensor
19201 to 102314
For more information about Entity MIB – Physical Table, see View Physical Entities.
