To avoid traffic interruption, enable alternative routes on the switch, to replace the best route with the next-best route if the best route becomes unavailable. By default, this feature is enabled.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select IPv6.
  3. Select the Globals tab.
  4. To enable IPv6 alternative routes, select AlternativeRouteEnable.
  5. Select Apply.
