View RSMLT edge support information to verify the RSMLT peer MAC/IP address-pair in its local configuration file and restore the configuration if the peer does not restore it after a simultaneous restart of both RSMLT-peer systems.
- Select RSMLT.
- Select the Edge Peers tab.
Edge Peers Field Descriptions
Use the data in the following table to use the Edge Peers tab fields.
Name |
Description |
VlanId |
Specifies the VLAN ID of the chosen VLAN. |
PeerIpAddress |
Specifies the peer IP address. |
PeerMacAddress |
Specifies the peer MAC address. |
PeerVrfId |
Identifies the Peer VRF. |
PeerVrfName |
Specifies the Peer VRF name. |
