View the VLACP port configuration to show the port VLACP configuration.
  1. To enter User EXEC mode, log on to the switch.
  2. View the VLACP port configuration for all interfaces:
    show vlacp interface gigabitethernet [vid <1-4059>] [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Switch:1>show vlacp interface gigabitethernet
                               VLACP Information
INDEX ADMIN   OPER    PORT     FAST  SLOW   TIMEOUT TIMEOUT ETHER      MAC
      ENABLED ENABLED STATE    TIME  TIME   TIME    SCALE   TYPE       ADDR
1/1   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
1/2   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
1/3   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
1/4   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
1/5   false   false   DOWN     200  30000   long     3      0x8103 01:80:c2:00:11:00
--More-- (q = quit)
                         VLACP Flap Detect Information
INDEX FLAP    FLAP    FLAP     TOTAL      FIRST-FLAP      LAST-FLAP
      DETECT  FREQ    INTERVAL FLAP       TIME            TIME
1/1   false   3       60       0          -- --           -- --
1/2   false   3       60       0          -- --           -- --
1/3   false   3       60       0          -- --           -- --
1/4   false   3       60       0          -- --           -- --
1/5   false   3       60       0          -- --           -- --
--More-- (q = quit)
Switch:1>show vlacp interface gigabitethernet 2/1 vid 2
		                                  VLACP Information
2/1     true      true     up     500     30000  short     3       0x8103   01:80:c2:00:00:0f
2/1       true       10      10	      4	  09/20/11 08:24:10    09/20/11 08:26:10
Switch:1>show vlacp interface gigabitethernet 1/7
                               VLACP Information
1/7   false   false   DOWN  200     30000    long     3      0x8103    01:80:c2:00:11:00
1/7   false   3       60       0          -- --           -- --
Variable definitions
Use the data in the following table to use the show vlacp interface gigabitethernet command.
Variable
Value
vid <1-4059>
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
The VLAN ID is in one of the following formats: A single VLAN ID (vlan-id), a range of VLAN IDs [(vlan-id)-(vlan-id)] or a series of VLAN IDs (vlan-id, vlan-id, vlan-id).
Specifies a port or list of ports to show only the VLACP information for those ports.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
