Use this task to display ExtremeCloud IQ Agent configuration information and status.
Display IQ Agent configuration information and status when IQ Agent is enabled using the default ExtremeCloud IQ server:
Switch:1>show application iqagent ================================================================================ IQAgent Info ================================================================================ Agent Admin State : true Agent Version : 0.2.7 Agent Oper State : connected Server Address : hac.extremecloudiq.com Server Address Origin : None Proxy Address : extremeiq.com Proxy TCP Port : 21 Proxy Username : admin
Display IQ Agent disabled state:
Switch:1>show application iqagent ================================================================================ IQAgent Info ================================================================================ Agent Admin State : false Agent Version : 0.2.7 Agent Oper State : disconnected Server Address : 0.0.0.0 Server Address Origin : None Proxy Address : 0.0.0.0 Proxy TCP Port : 0 Proxy Username :
Display IQ Agent configuration information and status when DHCP provides a dynamic server IP address:
Switch:1>show application iqagent ================================================================================ IQAgent Info ================================================================================ Agent Admin State : true Agent Version : 0.2.7 Agent Oper State : disconnected Server Address : 192.0.2.1 Server Address Origin : DHCP Proxy Address : 0.0.0.0 Proxy TCP Port : 0 Proxy Username :
Display IQ Agent configuration information and status when DHCP Client is disabled on the switch:
Switch:1>show application iqagent ================================================================================ IQAgent Info ================================================================================ Agent Admin State : false Agent Version : 0.2.7 Agent Oper State : disconnected Server Address : hac.extremecloudiq.com Server Address Origin : None Proxy Address : 0.0.0.0 Proxy TCP Port : 0 Proxy Username :
