Enable RMON Statistics
Enable Ethernet statistics collection for RMON.
- Select Control.
- Select the Ethernet Statistics tab.
- Select Insert.
- Next to Port, select the ellipsis (...).
- Select a port.
- Select OK.
- In Owner, type the name of the owner entity.
- Select OK.
- Select Insert.
Ethernet Statistics Field Descriptions
Use the data in the following table to use the Ethernet Statistics tab.
Name |
Description |
Index |
Uniquely identifies an entry in the Ethernet Statistics table. The default is 1. |
Port |
Identifies the source of the data that this etherStats entry is configured to analyze. |
Owner |
Specifies the entity that configured this entry and therefore uses the assigned resources. |
