Each PoE port has a configurable power limit. This configuration attribute limits the amount of power supplied on a particular port and varies across different hardware platforms. If a PD requires more than the configured limit, the device will not connect properly or is forced to run at a lower limit.
The following table lists the power limit for different hardware platforms:
Platform |
Power Limit |
5320 Series |
32 watts |
| 5420 Series |
32 watts:
98 watts:
5520 Series |
98 watts |
5720 Series |
98 watts |
